Keytool Challenge
Extranorrdinaut
Hallo Griga Had to reinstall the operating system due to some challenges, comes this error on installing the DVBViewer , could you help it would be great, thanks
User Data Error 752 Please Use Keytool to Enter The Correct Data
vor 2 Stunden schrieb Extranorrdinaut:
User Data Error 752
Looks like you have entered wrong user data. Is the displayed checksum correct?
Hallo Griga Checksum were found to be incorrect so corrected it then the software works fine again, thanks for youer help
with regards
