Sid Posted February 22, 2005 Posted February 22, 2005 There is a problem while using the recorder programming. When you plan to record more then one program, the second programming is recorded on the first channel. Auf deutsch: Wenn man bei der Recorder Programmierung zwei Aufzeichnungen plant, z.B. die erste auf Pro7 und die zweite auf WDR so wird auch die zweite auf Pro7 aufgenommen. Gruß Sid Quote
Griga Posted February 22, 2005 Posted February 22, 2005 What recorder are you writing about??? DVBViewer 3.0? Other version? Videorecorder Plugin? Quote
Sid Posted February 23, 2005 Author Posted February 23, 2005 What recorder are you writing about??? DVBViewer 3.0? Other version? Videorecorder Plugin? <{POST_SNAPBACK}> Im talking about the version 3.0 and the menu: "DVBViewer->Record Settings". Quote
Guest Lars_MQ Posted February 23, 2005 Posted February 23, 2005 I tested it and can't confirm the described problem. Could you please describe the steps you've taken so I can reproduce it? thanks lars Quote
Sid Posted February 23, 2005 Author Posted February 23, 2005 I tested it and can't confirm the described problem. Could you please describe the steps you've taken so I can reproduce it? thanks lars <{POST_SNAPBACK}> 1. I use the menu point: "DVBViewer->Record Settings" 2. In the window called "Recorder", i choose a channel like "Pro7. Now I program the start and the end time an choose the "add" button. In the list above the entry is correctly shown. 3. Now I choose another channel like "WDR" and program the start and the end time. I push the add button. For the second entry the list above shows the correct start and end time, but not the correct channel "WDR". It shows the channel "Pro7" from the first programming. It is not possible to program more than one channel correctly. Quote
