How to change "Menus" to "Windows Default" in 7.2.2.1
20220703
I was able to change "Menus" option in older versions, but it is missing in 7.2.2.1
If this opyion is removed, can anyone suggest other method to change the style of menus to "Windows Default"? thank you.
Launch Tweaker.exe (see DVBViewer program directory), search for the "Use DVBViewer menu stile" setting, untick it (and read the description at the bottom) and save.
Settings outsourced to Tweaker.exe are for experienced users who know what they do, because a change may entail drawbacks or require special knowledge.
  • Thanks 1
