Cannot find Channels with my WinTV 5525
PRAGMA MARKSMAN
Hi, I have used DVBViewer before and had it working maybe 1-2 years ago but currently I cannot get it working.
I dont know much about all the terms.
Im using the latest demo version before I possibly have to re-purchase due to lost key file.
Testing and I cannot get it to find any channels.
I'm in Ireland so I presume Astra 28.2'E, but my TV used Astra 28.5'E?
Do you have a transponder ini file for 28.5? Maybe thats why?
This is the Tuner I am using: https://www.hauppauge.co.uk/site/products/data_hvr5525.html
This is the hardware settings (i disabled /C and /T):
This is scan settings
Edited by PRAGMA MARKSMAN
No. It shouldn't make a difference. At least it doesn't here (western part of Germany).
Does the Hauppauge software (WinTV) work? Please note that it may disable HVR 5525 usage in DVBViewer due to a background service that accesses the card.
I don't know if it applies to your case, but some posts (also here in the German forum section) suggest that there is a problem with the Hauppauge HVR 5525 and a Windows 10 update that has been released in 2019. Please read more about it here. The old driver mentioned in the last post is still available here.
