Gerbi Posted February 27, 2005 Posted February 27, 2005 Hi, I purchased DVBViewer 3.0 recently and ran into a little problem. After I reboot my PC DVBViewer does not show a picture or sound when I start it. It just shows me that I have reception (around 70%) and not a black screen but rather a little brighter. It is similar to the short time between switching channels. The strange thing is, that after I started Key_DVB everything works fine. Key_DVB is also a DVBViewer program but mainly for recording and not as powerful as DVBViewer. That is why I switched to DVBViewer in the first place. Key_DVB starts without a glitch. And after that DVBViewer shows everything just fine. The really bad thing about this is that I used to put my PC into hibernate and use scheduled recordings, but that does not work anymore. The PC awakes but DVBViewer produces only 1kb files. So I hope you have some idea how to fix this. Thanx in advance for your help ----------------------------------------------- Some information about my system Athlon XP 2000+ Gigabyte GA-7vrxp 512MB Win2k Skystar 2 Driver 4.3 As said DVBViewer 3.0 InstalledCodecs.txt Setup.xml Quote
Hartwig Posted February 27, 2005 Posted February 27, 2005 execute the regfilter.exe from DVBViewer directory. It may help. Quote
Gerbi Posted February 27, 2005 Author Posted February 27, 2005 I did that, but it did not work. any other suggestions? Quote
Gerbi Posted March 9, 2005 Author Posted March 9, 2005 well, I formated my PC and the problem is gone. I guess it had something to do with the many codecs I had installed. I hope it stays that way. So long, Gerbi Quote
