cannot render Mediafile/Output Pin, error 0x80040218 No combination of filters
tablaman
gday.
i have had to reinstall my laptop.
DVBViewer loads okay but i get this dialog box
combination of filters could be found to render the stream.
could someone give me some help for this please?
[ i'm an Australian user]
regards
Most likely missing decoders. Install LAV Filters. Use Installer.exe and consider that DVBViewer as 32-bit-application requires the 32-bit-version. Additionally installing the 64-bit version is ok.
