Audio but no Video (black screen) 4:2:2 HDR content without OSD Filter with EVR
merkin stare
Here is a link to a sample ts:
https://drive.google.com/file/d/1xEPaUySVvKnGASgabpsMrSUVv7p0WgZh/view?usp=sharing
The video above is hevc 4:2:2 HDR.
DVBViewer shows a blank video screen using EVR.
If I goto settings > options > playback components, and select "Use OSD DirectShow filter" under "EVR Options", video is displayed correctly.
I have created and attached support files when OSD filter is enabled/disabled.
support_OSD-checked.zip support_OSD-uncheck.zip
Here it works neither with nor without OSD DirectShow Filter, unless I change the hardware acceleration on the property page of the LAV Video Decoder (see Settings -> Filters) from DXVA (native) to None.
I guess the graphics hardware can't decode the 4:2:2 chroma format.
