Low diskspace warning
aydan
it would be nice to have a low diskspace warning.
When programming recordnigs, there should be an evaluatoin of necessary diskspace and a warning should be issued if there's too little.
Bye
Aydan
Hello !
Problem is that DVBViewer CAN not KNOW how much Space a Movie will take.
You are 100% depending on the Bitrate = FileSize the TV-Company is providing/delivering.
If they provide low Bitrate a movie might have 1,5 GIG, the same movie with high Bitrate may Take 3,5 GIG.
So it is up to you to guestimate the necessary HD space.
Guest Lars_MQ
You may not know how big a moviefile will get, but you know when there is not enough space anymore while writing :mellow:
One way to go: have serveral capture folders on different disks. Trigger a split file and write to another disk if filespace gets low.
Or maybe an priority system. you can give your recordings priorities and if a recording with a higher priority can't be continued a recorded file with a lower priority will be automatically deleted.
I'd prefer a combination of both methods ;) Maybe Christian will implement multiple recording folders.
Do the stations change their bitrates? if not you could just remember the Bitrates for each station and give an estimate. Even if they do change their bitrates a rough estimate (worst case) would help.
They do - it may vary from 2 MBit/s for one broadcast to 4 MBit/s for another broadcast. So remembering and estimating "from experience" doesn't make much sense. Have a look at the property page of the DVBViewer filter (View / Filters). It shows the video bitrate as sliding average of the last 100 PES packets.
