Taghor Posted March 5, 2005 Posted March 5, 2005 Hello everybody, is it possible to record DVB-T Streams with DVBViewer in the background? So i can work normally with my computer and the recorder only streams the data on the disc without playing it? If this is not possible with DVBViewer anybody knows if there is another tool which has this feature? Thx in advance Taghor Quote
Guest Oliver Posted March 5, 2005 Posted March 5, 2005 is it possible to record DVB-T Streams with DVBViewer in the background? Yes. Bye, Oliver Quote
bergh Posted March 6, 2005 Posted March 6, 2005 Hello ! Waht Oliver seems to mean is, that you should read the manual, or you might want to have a look on the GE Edition of DVBViewer. Especially the command line options should have your attention. Of course everybody is talking about the Pro Version and not about the version delivered with the card. Quote
Guest Lars_MQ Posted March 6, 2005 Posted March 6, 2005 that you should read the manual, or you might want to have a look on the GE Edition of DVBViewer. You mean read the manual AND have a look at the GE Version. It doesn't matter if you want to use the 3.0 oder GE Version. Reading the manual is always good Quote
