Fulvio Spelta Posted April 4, 2023 Posted April 4, 2023 Hi all, I'm experiencing a strange problems. Long story short: Case ok: if i view a channel (hd) streaming it by media server to a pc in lan in "direct video" (vlc as renderer on the pc) i can see the audio/video perfectly. Caso ko: if i record using timer of the same channel, then i stream the recording again using "direct video" to the same pc and vls i have a lot of discontinuities. I have the same discontinuities even if i read the recorded .ts file both via lan or copied locally on the pc. The .ts file is recorded with the "TS, MPEG2 video as mpg" but i have the same problem (worse) using "Always TS" too. Any hint about how to troubleshoot ? Thanks a lot Quote
Griga Posted April 4, 2023 Posted April 4, 2023 vor 1 Stunde schrieb Fulvio Spelta: if i record using timer of the same channel, then i stream the recording again using "direct video" to the same pc and vls i have a lot of discontinuities. For further diagnosis, activate Media Server Options (SvcOptions.exe) -> Recordings -> Wrile log file and perform another recording. The recording log file (same name as the recording, but .log extension) will indicate all discontinuities in the arriving data before they are written to disk. It should clarify if the discontinuities occur before or after recording (on streaming). Quote
Fulvio Spelta Posted April 30, 2023 Author Posted April 30, 2023 (edited) Hi sorry for late answer, I've been busy. I've done the test suggested, this way (all steps in sequence with no pause): 1) watched for 10 min a tv channel HD using vlc on client and the "direct stream" option: fluid video and audio 2) closed vlc 3) started the same channel recording (10 min) with "!!Always TS" and audio in MP3 4) Stop the recording 5) watched the recording using vls and "direct stream": problems on video 5) watched the .ts file using vlc: problems on video Media Server Version: 3.2.4.0 Attached the log and txt files. In the log file errors are logged but i can't understand the cause. Thanks 2023-05-01_01-10-17_Rai 2 HD (AC3,ita)_Check Up - RUBRICA - L eccellenza della Medicina italiana dai.txt 2023-05-01_01-10-17_Rai 2 HD (AC3,ita)_Check Up - RUBRICA - L eccellenza della Medicina italiana dai.log Edited April 30, 2023 by Fulvio Spelta recording stream test + version added Quote
Griga Posted May 1, 2023 Posted May 1, 2023 7 hours ago, Fulvio Spelta said: In the log file errors are logged but i can't understand the cause. The errors are already present in the stream received by the Media Server, so there is nothing that can be done about it in the Media Server. A frequent cause for such drop-outs (missing data packets) are "aggressive" energy saving measures, that for example let the CPU cores often change to deeper sleep states (C-states) if the CPU load is low. Since recording only needs very little CPU power and waking up from deeper CPU sleep states takes some time, the tight timing requirements for live stream processing are not fulfilled anymore. Particularly USB DVB devices are affected by it. Such errors typically vanish, if the CPU is kept busier. We already had a long discussion about his topic here. Maybe it gives you some hints what you can try. Here you can read how additional CPU power settings can be made visible in the Windows advanced power settings. Please ask, if there are still questions. Quote
Fulvio Spelta Posted May 4, 2023 Author Posted May 4, 2023 Thanks Griga, i'll read the discussions (I've seen that they need a bit of attention 🙂 ). Just a quick curiosity: why the problem doesn't arise when i watch real time tv stream and coherently is present even in watching when the recording f the same channel is active? I can't figure out why the real time watching without recording is ok but is ko when recording is running. I suppose that the CPU suspension will occour in both cases. Thanks again f Quote
Griga Posted May 5, 2023 Posted May 5, 2023 On 5/4/2023 at 12:29 PM, Fulvio Spelta said: why the problem doesn't arise when i watch real time tv stream and coherently is present even in watching when the recording f the same channel is active? Who knows? I would first use this little Microsoft tool (read more about the usage here) to create a certain amount of additional CPU activity on the server PC for finding out if this avoids the errors. If yes, they are caused by energy saving measures. Quote
Fulvio Spelta Posted May 6, 2023 Author Posted May 6, 2023 I've setup the tool to have 60% cpu load with load on all the 4 cores but nothing changed: Device: ASTROMETA DTV Filter EventID: 160 Timer Name: Paradise La finestra sullo showbiz - INTRATTENIMENTO - Dall'Auditorium della Conciliazi Timer Start: 06/05/2023 06:55:00 Timer Duration: 01:45:00 (105 min. incl. 5 min. lead time, 10 min. follow-up time) Timer Options: Teletext=0, Subtitles=0, All Audio Tracks=0, Adjust PAT/PMT=1, EIT EPG Data=0, Transponder Dump=0 Timer Source: Web 08:30:21 / 00:00:00 (~ 0,00 MB) Start Recording 08:30:22 / 00:00:00 (~ 0,00 MB) Gli imperdibili running | EventID: 161 PDC: 0x00000 08:30:23 / 00:00:01 (~ 0,38 MB) PID 302: AC3 Audio Stereo, 48 khz, 384 kbps 08:30:23 / 00:00:01 (~ 0,38 MB) Meglio di Radio2 Social Club not running | EventID: 167 PDC: 0x00000 08:30:24 / 00:00:02 (~ 1,12 MB) PID 202: H.264 Video, 16:9, 1920x1080, 25 fps 08:30:28 / 00:00:06 (~ 3,60 MB) Errors: 2 08:30:29 / 00:00:07 (~ 4,20 MB) Errors: 1 08:30:31 / 00:00:09 (~ 5,49 MB) Errors: 1 08:30:32 / 00:00:10 (~ 6,14 MB) Errors: 1 08:30:34 / 00:00:12 (~ 7,42 MB) Errors: 1 08:30:37 / 00:00:15 (~ 9,51 MB) Errors: 1 08:30:44 / 00:00:22 (~ 13,81 MB) Errors: 1 08:30:49 / 00:00:27 (~ 17,01 MB) Errors: 1 08:30:54 / 00:00:32 (~ 20,15 MB) Errors: 1 08:31:07 / 00:00:46 (~ 28,37 MB) Errors: 1 08:31:11 / 00:00:50 (~ 30,79 MB) Errors: 1 08:31:42 / 00:01:20 (~ 48,72 MB) Errors: 1 08:31:43 / 00:01:21 (~ 49,30 MB) Errors: 1 08:31:46 / 00:01:24 (~ 50,97 MB) Errors: 3 08:31:47 / 00:01:25 (~ 51,59 MB) Errors: 1 08:31:58 / 00:01:36 (~ 56,57 MB) Errors: 2 08:31:59 / 00:01:37 (~ 57,09 MB) Errors: 1 08:32:03 / 00:01:41 (~ 59,58 MB) Errors: 1 08:32:06 / 00:01:44 (~ 61,49 MB) Errors: 1 08:32:09 / 00:01:47 (~ 63,11 MB) Errors: 1 08:32:10 / 00:01:48 (~ 63,60 MB) Errors: 1 08:32:13 / 00:01:51 (~ 65,38 MB) Stop Quote
Griga Posted May 7, 2023 Posted May 7, 2023 On 5/6/2023 at 8:39 AM, Fulvio Spelta said: I've setup the tool to have 60% cpu load with load on all the 4 cores but nothing changed Proves that energy saving is not the cause (or not the only cause). What happens if you record a channel and stream it simultaneously? This does not require two tuners. The Media Server will use the same data source for both. Quote
Fulvio Spelta Posted May 11, 2023 Author Posted May 11, 2023 Hi Griga, after reading the posts about the problems due to energy management I've done some tests and, long story short, the solution is: use a usb hub with a dedicated power supply and to use a non-usb storage for the recorded stream. Using this configuration it seems that no errors occur. Hope to have more time to better understand the root cause; if I'll have more info I'll post here to share. Really thanks for your support. f Quote
Fulvio Spelta Posted May 18, 2023 Author Posted May 18, 2023 Hi all, after further test i can share that the main cause of errors seems to be some kind of "collision" on usb bus. Avoiding to use the usb disk solve the errors. To extract the knowledge from this case i suggest anyone with same problem to: Provide power supply to dvb-t stick Use a non usb disk as target storage Thanks again for support. Quote
