Derrick Posted March 6, 2005 Posted March 6, 2005 ..the answer is, get it from Lyngsat with Fritzmaiers Editor The editor is designed for the dbox2 with linux. But a useful feature is the extraction of prog's transponder.ini format. The text file can be edited if you click on the progdvb-support tab. Transponders that can not be received cos the dish is too small or the beam can´t be received, can be deleted (that was my wish because I love this feature in transedit ). The (edited) ini files have to be copied into the transponder folder of the DVBViewer and then can be scanned either with the DVBViewer or with transedit (which I prefer ). Don't forget your personal lnb/diseqc settings.. http://members.tripod.com/fritzmaier/cgi-bin/tuxbox.html ps. it's possible to add any satellite position from lyngsat in a satellite.ini file I´ve attached my own messy satellite.ini Quote
Derrick Posted March 6, 2005 Author Posted March 6, 2005 ..you won´t need the services.xml and bouquets.xml but the tool asks for these files Quote
