Qosmio Posted July 28, 2023 Posted July 28, 2023 Hi, With the last update to 3.2.4 Media Server i don't receive an email after recordings are finished, i do get an email when auto search adds new timers and the test email works fine to. Both options to send an email are checked of course. Any idea's? Quote
Griga Posted July 28, 2023 Posted July 28, 2023 vor 54 Minuten schrieb Qosmio: With the last update to 3.2.4 Media Server i don't receive an email after recordings are finished Just performed a short test. Here it works. So more details are required for investigating under which circumstances it doesn't work. A support.zip would be a good start. Quote
Qosmio Posted July 29, 2023 Author Posted July 29, 2023 If it works on your site i will not bother you further i will figure it out and do a clean install. tnx Quote
