Xbox usb tuner
Hi everybody !!!
Is there any way to use Xbox usb tuner with DVBViewer and search DVB-T channels ?
Thanks in advance !!
On 8/17/2023 at 7:49 PM, Griga said:
There is only one way: You need to find a BDA driver for it. Maybe this link will give you some additional hints:
https://www.reddit.com/r/htpc/comments/hjzp2r/does_the_xbox_one_tv_tuner_have_windows_drivers/?rdt=54906
Thanks ! I've followed this info and get channels with ALT_DVB as can be seen in the pic below... any idea how to recognize xbox usb tuner in DVBViewer? it doesn's appears in the hardware list :(
Settings -> Options -> Hardware -> Scan Devices doesn't help?
Where does the device appear in the Windows Device Manager? The expected section for TV tuners with BDA driver is "Sound, video and game controllers".
  • Like 1
NOP  :(
 It appears at Universal Serial Bus devices
Edited by Griga
Wrong quoting corrected
Sorry, DVBViewer does not support this kind of interface. It would take quite some efforts to implement it. So there is at least no short-term solution.
  • Like 1
Hello,
until then, you could plug a DVB-T or DVB-T2 HD stick, whatever standard is offered in Spain, into the USB port.
These are offered quite cheaply. For example, I bought an Astrometa stick or one offered under a different name from Amazon for less than €30. And it works fine with the DVBViewer (at least on my W 10 64-bit Lenovo notebook). Depending on the reception conditions, the supplied rod antenna is sufficient for this, as it was for me.
Many greetings
Webturtle
Google Translator:
Hola, hasta entonces se podía enchufar al puerto USB un stick DVB-T o DVB-T2 HD, sea cual sea el estándar que se ofrezca en España. Estos se ofrecen a un precio bastante económico. Por ejemplo, compré un bastón Astrometa o uno que se ofrece con otro nombre en Amazon por menos de 30 €. Y funciona bien con DVBViewer (al menos en mi portátil W 10 de 64 bits). Dependiendo de las condiciones de recepción, la antena de varilla suministrada es suficiente para ello, como lo fue para mí.
  • Like 1
