Timeshifting controls in v2.2??
Sean C
Hi Guys,
Now that I have rolled back to 2.2, my silent recording problems are over, but now I don't see any way to get the timeshifting controls to pop up.
Moved the mouse off bottom of the screen and nothing.
Were these controls only introduced in v3.0, or is there a way of getting similar controls in v2.2?
I haven't installed a remote, perhaps that would allow me to fast forward?
Cheers...Sean!
Guest Lars_MQ
Just have a look at the options, there you have to enable this option and can adjust the "popup" time.
lars
Well, bugger me, thats just perfect! Had it set to zero, which also disabled it. Now I don't need to upgrade.
Thanks Lars!
