Media server and Kodi (PVR plugin)
JonasHansen
I am using DVBViewer Server as mu backend on a Win 11 server and Kodi as my front also on Win 11.
The PVR plugin (DVBViewer) that I use in Kodi gives me problems in recording series.
They are almost always "deactivated" when I look in the specific recording, and I have to click "activated".
Is this known and am I doing something wrong in my settings?
Thanks
/Jonas
How/where did you set up series recording?
Series recording executed by the Media Server is based on EPG search presets, that automatically create recording timers for programmes whose EPG entries contain a certain search item.
Search presets can be configured in detail on the "Search EPG" page of the Media Server web interface. Select the search preset in question in the dropdown list at the top, adjust the "Create auto-timers deactivated" section at the bottom right to your needs and click "Save".
