e123enitan Posted October 10, 2023 Posted October 10, 2023 Appreciate any assistance, I have below links that functions perfectly when inputted into Kodi PVR IPTV Simple with works flawlessly, I have search through DVBViewer client and DMS I couldn't find any possible function or location to inputs these urls Any thoughts? Thanks, Channel List https://tvnow.best/api/list/username/password/m3u8/livetv</ EPG List https://tvnow.best/api/epg/username/password/full.xml.gz Quote
Griga Posted October 11, 2023 Posted October 11, 2023 Both URLs yield a short MP4 video showing an error message due to missing user name and password. So I can't examine the content. There are commandline parameters that let DVBViewer import channel lists referenced by a URL. Please read more about it in the DVBViewer 7.2.0 release notes and here. However, in your case it will only work if you can pass the user name and password as part of the URL. If DVBViewer is configured as client of a Media Server on the same PC, it automatically saves the changed channel list after the import (since DVBViewer 7.2.3). The Media Server loads it automatically as soon as it recognizes that the channel list has been changed (usually within one second). Importing XMLTV EPG data in the Media Server requires the Xepg tool. Quote
