Converting percent to dBm in DVBViewer
QB
I am using DVBViewer Pro to view input on my TBS 6900x DVBs/S2 cards, it displays a signal strength in the status bar in percentage, however, I would like to convert that to dB or dBm. How can I achieve that? what is the conversion rate for DVBViewer? Also, how can I find SNR or signal to noise ratio using it? and if I cannot using DVBViewer, what software do you suggest?
- QB
Not possible in DVBViewer. You may want to try CrazyScan.
