manmas Posted March 10, 2005 Posted March 10, 2005 Hi, I have this problem: Can't disable AV when recording with Recorder or Video-Recorder. I have set "Default Disable AV" in options/recorder/recordings, but nothing. Why ? Quote
admi-ral Posted March 10, 2005 Posted March 10, 2005 while using v3 there is a bug programming in epg-window (not osd). you have to check the button in the timer-window afterwards. try to program via OSD-Timeline or OSD-EPG, the disable av option should be checked in timerwindow Quote
manmas Posted March 13, 2005 Author Posted March 13, 2005 I've tryed via OSD-Timeline or OSD-EPG but nothing. I can't stop rendering while recording at all. Quote
