No hardware available - This device is working properly !
bogdan29
Suddenly i encounter this message: No hardware available.I check in device in manager and everything seems to be fine with message: This device is working properly !
So whats going on ?i don 't understand what happen😐
https://imgur.com/a/4rE8QPj
Edited by bogdan29
There are some possible reasons, e.g. the Windows BDA sub-system may be damaged, which would require a Windows repair installation.
However, the screenshots show that you are using a very old DVBViewer version released before 5.6.0 / 2016. We cannot provide support for such old versions anymore.
12 hours ago, bogdan29 said:
and the result is the same
But there is no "no hardware" message anymore?
with latest version of DVBViewer there Is no message:  "no hardware " ,but PMT and SDT is red and no channel found anymore.....
windows problem or hardware probem...
https://imgur.com/a/1BFmPTQ
Edited by bogdan29
Just a guess: Windows has changed the hardware ID of your USB device (Windows sometimes does for unknown reasons), so your old installation doesn't find it anymore. DVBViewer Demo doesn't have this problem because it did a new device detection after installation. In this case you also need to perform a device detection with your old DVBViewer on Options -> Hardware.
This means that nothing has been received on a frequency and/or with the given parameters. Dunno why...
On 12/18/2023 at 6:44 PM, bogdan29 said:
is not USB device.
I would try to perform a device detection in your old installation anyway.
