Project X 0.82.00.05
OoZooN
ist online. wie immer hier
Project X 0.82.00.05a (patch)
13.03.2005
fix - CLI start error (from 0.82.00.05)
fix - nullpointerexception demuxing de-selected stream types
fix - some ac3 streams were not identified (the '=>sPES' switch is still important)
fix - CLI switch [-g] hasn't started the GUI
fix - arrayexception detecting wrong video headers
change - drops a Gop what exceeds a maximum size for SD resol.
change - updated language files
change - updated commons-net lib (to version 1.3.0), fixes some ftp issues
change - when dropping 'c.d.f', it also clears user_data in video
change - when dropping Mpa-CRC, it also clears private_bit in audio
add - collection context menu option to define a new output base filename (like the CLI switch [-o])
add - detects + decodes VBI-data streams (VPS + WSS labels) for info only (used by ORF[Austria])
Edited by OoZooN
