Elecard
Guest Oliver
Guest Oliver
Hello!
I have the Elecard MPEG decoder installed, which is used for playback as can be seen in graphedit. How do I switch to another codec, for example the original Microsoft demultiplexer without deinstalling the Elecard decoder?
CU, Oliver
That´s a interesting question. I still haven´t found a program to do that.
But it should be possible to change it in the registry.
Ok. I have a solution to do that. Goto:
HKEY_CLASSES_ROOT\CLSID\{F50B3F13-19C4-11CF-AA9A-02608C9BABA2}\InprocServer32\
And rename/remove the (Standard) entry: C:\Programme\ElecardDecoder\mpgdec.ax
You can create two .reg Files
1. ENABLE.REG
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\CLSID\{F50B3F13-19C4-11CF-AA9A-02608C9BABA2}\InprocServer32]
2. DISABLE.REG
@="C:\Programme\ElecardDecoder\mpgdec.ax"
So you can enable/disable the Elecard encoder with one mouse click without install/deinstall the codec.
Guest Oliver
Hello Skandler!
Thank you, very good and usable solution! :rolleyes:
CU, Oliver
