Hamad Nasser Posted February 16, 2024 Posted February 16, 2024 Hi dear, tbs6909xv2 was tested on DVB DREAM. It successfully defines Stream Reader without problems. Tried it on DVBViewer but it doesn't work. This is because DVBViewer supports BDA definition. Please help me solve the problem with the TBS 6909xv2 card, thank you. Quote
Griga Posted February 16, 2024 Posted February 16, 2024 vor 23 Minuten schrieb Hamad Nasser: Tried it on DVBViewer but it doesn't work. This is because DVBViewer supports BDA definition. Sorry, DVBViewer does not support the StreamReader interface. But TBS provides a BDA driver for the TBS 6904 card, doesn't it? There is an entry for it in the DVBViewer hardware database. So it should be possible to use it with DVBViewer. Quote
Hamad Nasser Posted February 16, 2024 Author Posted February 16, 2024 (edited) What is the solution for the tbs 6909xv2 card to work properly on DVBViewer? Edited February 16, 2024 by Hamad Nasser Quote
Griga Posted February 16, 2024 Posted February 16, 2024 DVBViewer should work properly if a BDA driver is installed. Please don't double-post! Double postings will be deleted! Quote
