DVBViewer & [removed, violating forum rule §13 ] for Feeds
11 hoangtu
Hello and a wonderful good day.
I signed up here because I would like to use DVBViewer with [removed, violating forum rule §13 ] but can't get it to run.
My only concern is to get feeds bright.
Currently using DVBViewer 7.2.5 and [removed, violating forum rule §13 ] 2.4.6f1.
I unzip [removed, violating forum rule §13 ] into Plugins folder and change [removed, violating forum rule §13 ].ini with editor to activate everything.
After that I have to delete the vhelper.mdl, otherwise DVBViewer will not start.
Does this fit so far or do I already make a mistake here?
In any case DVBViewer can be started now again and [removed, violating forum rule §13 ] is active.
Only where can I now enter the keys that are posted?
Maybe someone here takes a short time and helps me.
Gladly also a step by step instruction.
Many thanks in advance.
Sorry, you are asking for something that cannot be supported here, because it is illegal in Germany. You will have to ask somewhere else.
Topic closed.
  • Like 1
