HTPC frontend!
faktor
How to activate the htpc frontend so that i can choose weather, tv, etc. Or should i put in some plugin into DVBViewer to activate that frontend. I can't find anything in some menu!
Please help me out.....
I'm talking about the screanshoot where you have this HTPC look. Maby it's just a scin but what skin is it in that way?
I need to do DVBViewer wife friendly :D
  • 4 weeks later...
ESC key.
Bye
Sorry but i have the problem to find the frontend, too. :wacko:
What went wrong? :blush:
Edited by Das ol
Well the HTPC System is part of the Proversion and offers these functions. The TE does not have such a thing inside.
Christian
Guest Lars_MQ
What went wrong?
Nothing, that's how it works. Simply select the item htpc menu.
