aydan Posted March 24, 2005 Posted March 24, 2005 I had the following problem several times already. today's situation was the following: Timeshifting Galileo on prosieben recordings scheduled for 20:10 on Sat1 and K1 after finishing galileo at 20:14 i switched to sat1 and the video started jerking. rebuild graph didn't work. stopping the recordings didn't work either. DVBV restart didn't work. Channel switch locked the DVBV. I had to reboot to solve the problem. Seems something broke the SS2 driver. I have TS and recordings on different HDs and one IDE channel each. The system runs on another HD. Quote
aydan Posted March 24, 2005 Author Posted March 24, 2005 It just happened again. One recording running on K1 timeshiftung on sat1 and a recording started on P7. Quote
aydan Posted April 3, 2005 Author Posted April 3, 2005 I noticed rthis only happens when a scheduled recording is starting, not if you start it manually. once i had four recordings running and was timeshifting w/o problems. But running one recording and another scheduled one starting will bring DVBV down. Quote
