nefarious Posted March 27, 2005 Posted March 27, 2005 Hi, I run dual displays, one being an HDTV (set up as an extension of my desktop - as the secondary monitor) set up using powerstrip. Previously the DVBViewer window would load in the TV display, but it has since disappeared (due to a game playing around with the monitors and fullscreen i think) and isn't showing on either the TV or the monitor. Is there a way to force the DVBViewer window to show on the primary display? I've tried disabling all displays but the monitor, but it still doesn't appear. I know it's running fine, because I can hear the sound, and access all menus (which all appear on the monitor display when I right click the icon in the system tray) and also when I fullscreen the output, it goes to fullscreen on my monitor display. Any ideas? Thanks Quote
Griga Posted March 27, 2005 Posted March 27, 2005 DVBViewer version? Check the X= / Y= values in the file Setup.ini / Setup.xml (use a text editor!), that define the window positions on the screen, and set them to 0. The main window is frmMain. Probably the window is outside the visible area. Quote
nefarious Posted March 27, 2005 Author Posted March 27, 2005 Wow, that was quick! That fixed it, thanks Griga, you're a champion. It was version 3.0, so it was in setup.xml. And yep, the window was way off the screen: <entry name="X">-976</entry> <entry name="Y">165</entry> Quote
