Green Posted March 27, 2005 Posted March 27, 2005 I already checked this link: http://www.DVBViewer.com/griga/Sender.html#Suchlauf The link there to the new transponder list doesn´t work. Where else can I get the newest transponder list? Quote
Griga Posted March 27, 2005 Posted March 27, 2005 Check this part of the board. You'll find several up-to-date channellists there, and a hint from Derrick that tells you how to get transponder lists. Or, if you are too lazy for that (like me ), download DVBViewer_GE.zip (see Service Center), that contains some up-to-date lists (thanks to Derrick, who provided them). Quote
Green Posted March 27, 2005 Author Posted March 27, 2005 (edited) Check this part of the board. You'll find several up-to-date channellists there, and a hint from Derrick that tells you how to get transponder lists. Or, if you are too lazy for that (like me ), download DVBViewer_GE.zip (see Service Center), that contains some up-to-date lists (thanks to Derrick, who provided them). <{POST_SNAPBACK}> Well, thx, but the goal I want to reach is to get Pro7 HDTV. I put the downloaded file into the transponders folder, right? Then I updated and scanned but I couldn´t find pro7 HDTV. Another way would be to give me the settings for the pro7 HDTV programme. Im searching for them like one hour or more, but I only can find the standard specs. I don´t know how to type them in (video/audio PID) I heard something about hex etc. I don´t know how to use this. Could anybody give me the correct settings for pro7 hd? I still need the LOF, Video/Audio/Teletext/Service PID EDIT: ASTRA 1FTransponder Nr. 16 Frequenz : 11.4355 GHz Polarisation: vertikal Symbolrate : 22 MS/s QPSK FEC : 5/6 Network ID: 0x0085 Original Network ID: 0x0085 Transport StreamID: 0x0006 Service ID: 0x0292 PMT PID: 0x0060 Video PID: 0x00FF- 1920x1080i, 50Hz PCR PID: 0x00FF Audio PID: 0x0103 DolbyDigital Service Name: ProSieben HD Service Provider: ProSiebenSat1 How can I convert the PID´s so I can use them in the DVBViewer and edit a channel correctly? Or could someone do this for me? Edited March 27, 2005 by Green Quote
Griga Posted March 27, 2005 Posted March 27, 2005 Attached a complete transponder list for Astra 19°E plus an INI file that only contains Pro7 HD. Import it in the channellist window. Astra_19E.zip Quote
