Sidebar for the DVBViewer
Guest Lars_MQ
I've uploaded the Sidebar for DVBViewer into the betasection of the membersarea. You'll need the remote control plugin to make it work.
The sidebar is a tool which like the taskbar can be docked to the left or right side of the screen. It also has autohide capabilities.
What does it do?
With the sidebar you can remote control the DVBViewer locally or via network. It also shows the channels and favourites in an easier to use form.
You can setup everything in the option-dialog of the sidebar, but remember the DVBViewer must be running and the Remote Control Plugin must be activated (and the IP of the computer connecting to it must be allowed in the svrphost.ini).
It may take a short moment till all lists of the channels and favourites are processed, depending on your computer / lan speed...
Have Fun
lars
wishes and sugestions are as always welcome :blush:
Bug in right & down arrow, look below.
ps. sorry for double post :(
Edited by Adam T.
Guest Lars_MQ
Strange, thanks I'll fix it :(
[edit] I've removed your double post :) [/edit]
  • 6 months later...
Guest Lars_MQ
A new Version (1.0) of dem DVBViewer Sidebar in the membersarea/tools. It doesn't need the remoteplugin, instead it uses the COM Interface of the DVBViewer 3.2.4+
