Mp3 Playback (freeze)
Scurra
hi there,
i got the following problem:
i start up DVBViewer - go to htpc mode - choose music - open my first folder - open the subfolder - choose the first file and press return. then DVBViewer freezes. i don't know why but some mp3 files work but some don't. i can't offer a lot of information to this bug but the following:
this is some information about the mp3 file (works fine in winamp):
Header found at: 1544 bytes
Length: 261 seconds
MPEG 1.0 layer 3
192kbit, 10041 frames
44100Hz Stereo
CRCs: No
Copyrighted: No
Original: Yes
Emphasis: None
my pc:
xp 1800+
512 mb ddr
xp sp2
audigy 2 zs
i put codec to auto but i installed the intervideo codec so i assume this one will be used.
i hope you can help
mfg scurra
Guest Lars_MQ
Maybe this Thread can help you. You should try another audio decoder if possible.
My guess: it's a direcshow / decoder problem.
