saeder Posted March 29, 2005 Posted March 29, 2005 Hi all! I'm using DVBViewer 3.0. I tried to set up a new HTPC with just a remote control and no keyboard and mouse. Well to configure it I use both keyboard and mouse. Every time I start it it says Winlirc failed to initialise. Then I press reconfigure, set it to COM1 - and it works! But every time I restart the PC it comes up with the same message. I tried to search the forum fro similar problems - but failed. Why dows'nt it remember the setting? It seems to execute ts_winlirc.exe in the DVBViewer directory. Help is appreciated very much. Quote
saeder Posted March 30, 2005 Author Posted March 30, 2005 Problem solved. I replaced ts_winlirc.exe by winlirc.exe. This works fine. I'm still curious what's the difference between the ts_winlirc and winlirc. Quote
