Tuner lockup
aydan
Yesterday i had a tuner lockup again. It happened after switching from K1 to Jump and back. DVBV just quit on me. after restarting DVBV i was unable to to tune into another channel. There just was no picture or sound. Another restart didn't work either. Since I didn't want to reboot i tried DVBV TE and it worked, sort of. I could tume all channels except K1. Only after switching back and forth several times I could tune K1 again. Seems DVBV somehow screwed up the SS2 driver. Afterwards DVBV worked again.
Sounds like a problem with your LNB or switch and not with DVBViewer
how come i could tune P7, N24 & Sat1 which are on the same transponder?
Also i'm plugged directly into a twin LNB.
A possible solution is to "reset" (or better, switching off the supply of...) your LNB...
For this task you can use a little utility, "FreeLNB-Tool", that Oliver mention in his precious manual... unfortunately it seems that the file isn't there anymore...
Anyway you can download a similar tool, called "LNB Off" (or is the same? I can't test at the moment) by clicking there.
I hope this will help...
and maybe you have wrong settings for K1.
Made a channelscan and post your settings for K1.
AND PLEASE give us needed informations !
Hm, I'm using the original Channellist from DVBV 3.0 so there shouldn't be a problem.
Here's my config file:
and what are your settings for K1?
I dont understand why you can look K1 here in this thread and here in this thread you thread you can't :huh:
My setting for K1:
Frequency 12480 MHz
Symbolrate 27500
Polarity Vertical
FEC auto
Video PID 511
Audio PID 512
Teletext PID 33
Service PID 899
PMT PID 101
PCR PID 511
LNB 22kHz
LOF 10600
After restrating DVBV the last channel is being retuned. If it was K1 you'll get K1 again, but after tuning another channel you can't get back to K1. Strange isn't it?
I'll try to reconstruct this situation on other transponders as well. If it happens there also it might be something that has to to with DVBV's recording/tuning mechanism.
Also: Why it DVBV TE able to cope with the tuner lock and DVBV3.0 isn't?
I just had the same problem on RTL/RTL2/VOX
I was timeshifting on vox and added recordings for current shows on RTL/RTL2.
as soon as the recordings started the video jerked. Removing the recordings didn't resolve the problem.
The first time a rebuild graph helped.
The second time the problem persisted even after a restart of DVBV
freelnb didn't help either.
only starting DVBV TE resolved the problem.
It seems something upsets the driver and DVBV TE seems to fix this. :huh:
PS: My recording HD's are two brand new Samsung SP2014N on a Advance Sil630 UDMA-133 controlle each with their own channel. so speed shouldn't be a problem.
Edited by aydan
Seems as if my modem driver (conexant) wreaks havoc on the SS2 driver. I hadn't noticed because I'm online most of the times I watch TV. When there's lots of traffic the symptoms seem to become more noticeable. So there's probably nothing you can do about this. I'll try to get myself another modem and try some more.
Well, it seems i wasn't the modem driver. I'll try again with a fresh windows installation and report back if it worked.
Seems I got myself a faulty harddrive. :wub:
It simply took the harddrive too long to write the data.
But I'm still concerned that the driver/viewer can't recover from such data lags.
Did you enable buffering in the options? If yes, how many MB?
I had set it pretty high but reduced it now to 4MB.
It does work now on another HD.
