ehker Posted June 7, 2024 Posted June 7, 2024 (edited) Reinstalled Windows along with DMS and DVBViewer. Started an EPG update today after scanning the channels only to realize that the EPG information was wrong and offsetted by 9 hours. I then realized that my PC time was correct but in wrong time zone. It was in UTC-8 (-7 due to daylight savings) and changed it back to UTC+2 (+3) which was my time zone. Now after doing it, DMS won't start a EPG update. Stopping EPG update says that the stopping can't be executed because there is no EPG update running. Checking tuner status after clicking start EPG update shows no sign of any EPG update occurring. Also while hovering over the DMS logo in web interface, it says "Timers active: 0" when there is on running and "Next timer starts:" with no text after it, when there are timers scheduled. Also my PC name is showing up correctly next to the version. Timer status and the next timers start time shows up when hovering over DMS tray icon in the taskbar. What can be done? Running latest DMS version 3.3.0.0 OS: Windows 11 Home Edited June 7, 2024 by ehker Quote
Griga Posted June 8, 2024 Posted June 8, 2024 Please provide a support.zip as attachment. it will save queries and shorten the support procedure. vor 12 Stunden schrieb ehker: Also while hovering over the DMS logo in web interface, it says "Timers active: 0" when there is on running and "Next timer starts:" with no text after it, when there are timers scheduled. Are the timers visible on the Timers page of the web interface? If yes, are the timers enabled (green dot on the left) or deactivated (grey dot)? Quote
