quality of recording file
mty
Why I get like horizontal lines in moving picture (even slowly), when I play back
recording file. I there no change if I watch the m2v file it self (by variety of player)
Or if I convert it to AVI or Mpg (I try with variety of tools)
Guest Oliver
Hello mty!
This is called "interlace". You have 25 frames per second which consists of each 25 upper and 25 lower fields which are not "correctly" integrated (roughly spoken). That means, you have to use a de-interlace filter, in VirtualDub for example Donald Grafts "smart deinterlacer", when converting to DiVX. Some broadcasts are progressive, there is no need for de-interlacing. That's no bug, you have to live with it. You could use the Elecard de-multiplexer for watching recorded MPG2-files, 'cause it has a de-interlacing function integrated (at least in the latest beta 2.00).
CU, Oliver
