aydan Posted April 11, 2005 Posted April 11, 2005 Hi, I just tried to get the visualization to work but I failed miserably. I can see the plugins in the dropdown list but after choosing one and pressing Apply and/or OK and even after a retune and a complete restart of DVBV nothing showed up. I tried with VMR9 and Overlay. Quote
Gioxy Posted April 11, 2005 Posted April 11, 2005 As far as I know the visualizations work only when DVBViewer play an audio-only stream, like a MP3 file or a radio channel... and if you are talking about DVBViewer v. 3.0, make sure you do no longer have the old Visualplugin... Quote
Guest Lars_MQ Posted April 11, 2005 Posted April 11, 2005 Maybe the RLDumper.ax filter from the DVBViewer\filter dir is not registered correctly. And the visuals work only for audio only stuff (mp3/radio) Quote
aydan Posted April 11, 2005 Author Posted April 11, 2005 How can I check if the filter is registered? And how can I get it registered? Quote
Griga Posted April 11, 2005 Posted April 11, 2005 http://www.DVBViewer.com/oliver/Filter.html#Filter5 Quote
aydan Posted April 11, 2005 Author Posted April 11, 2005 Well, it's not registered. Do I have to reinstall DVBV? Quote
Hartwig Posted April 11, 2005 Posted April 11, 2005 If the Filter is in DVBViewer\Filters\, you must only execute the regfilter.exe Quote
