Very Big problem
DAddYE
Hello, Im a new customer, login daddyez@tin.it
I've just installed the new version of DVBViewer, and I've some problem, is impossible for me swich channel by channel, because DVBViewer freeze.
I've a sempron 2200, 1gb of ram, Skystar2, Nvidia fx 5200 and all driver are the last.
Ive trayed to changhe the codec mpeg2 form the setting but the problem is the same, other Ive some problem with time shift, because is not possible pause stop and play, ff, rr...
I've attached setup.ini setup.xml and DVBViewer.log
Some of my log:
12/04/2005 3.19.04 EInOutError raised by instance frmMain of class TfrmMain at 00635EB0:Ungültiger Dateiname
12/04/2005 3.20.06 EInOutError raised by instance frmMain of class TfrmMain at 00635EB0:Ungültiger Dateiname
12/04/2005 3.21.44 EAccessViolation raised by instance tmrOSD of class TTimer at 0061E098:Zugriffsverletzung bei Adresse 0061E098 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000
Why this problem?
Thanks so much
I attend any answer
ps. so DVBViewer I a good work, very good work, but if is possible to import xml epg are much better!
Setup.ini
Setup.xml
oh,
could you try to remove the setup.xml file?
The error seems to be caused by the OSD system which is probably unable to find something.
Christian
Guest Lars_MQ
Where did you get the setup.ini? did you simply install over a old installation?. Maybe there are incompatible plugins. Try simply installing the 3.1 new parallel to the old installation.
thanks so much, ive just installed DVBViewer in other directory and every thing same to go well...
but I've only one problem, the only codec that work correctly is sonic, the other, intervideo, cyberlink, nvidia, discaler, mpeg2dec and some other dont'work very well, I've some problem of strech and some time the image freeze...
What I do for correct them?
Thanks so much
DAddYE
