Little Bug
DAddYE
I don' know if is only my problem, but when I send the pc in standby s3 a the resume DVBViewer don't tune on any channel...
Why?
Thanks so much...
Did you exit DVBViewer befor going to S3?
I think DVBViewer must be closed, then S3 and then start DVBViewer again. (at least with hibernate this is true)
no, because I wont the pc only for tv viewing and my simple "request", if is possible, is to send, when I see a channel, the pc in standby s3 and when I resume my pc the possibility to continue my view on the same channel...
In your opinion is possible?
Edited by DAddYE
Äh,
I haven´t tested the 3.1 yet (waiting for new Twinhan card :) ), but if you send your PC to S3 via DVBViewer, I think it should work. Bur some od the coders here can surely help you I think.
Sorry,
Rince
Ive just tested it, but is the same...
The problem is the codec...
for go the pc in standby s3 is necessary that DVBViewer when recive the input (for standby) stop tv, send the pc in standby, and at the resume, play the channel.
Is the same thing that do mce.
