AC3 (Dolby Digital) trough SPDIF
Unauthorized
To enable SPDIF:
1. Download & install AC3-Filter 0.55b (by Vigovsky Alexander)
2. Open an AC3-AVI-file with Media Player 6.4 to make your settings for the AC3-Filter
3. In DVBViewer chose Marfi's Renderer
4. Create a new channel for Pro7 with audio-pid 257 and select AC3 (only Pro7 gives us AC3 ;))
5. Switch to that channel :ph34r:
This should give you the AC3-signal and enable your decoder to do his job! :rolleyes:
The only thing I'm still having problems with is to record and work with AC3-Mpegs
Good info !!!
The recording problems should be history if Christian will create a Stream recorder. You could even record the stereo and Ac3 together or multiple audio channels together.
It would be an excellent replacement for recorder.exe.
No sync problems,no missing frames just original data.
I already did it building a graph with graphedit,recording 8 audio channels and demuxed with ds.jar.
Works great.
Cu Flepp
Yes, recording the original stream would be the best solution.
Cool, let's try it... :rolleyes:
EDIT: Works fine, just as 0.55b.
EDIT2: Updated How-to for 0.63b:
To enable SPDIF:
1. Download & install AC3-Filter 0.63b (by Vigovsky Alexander)
2. Launch 'AC3Filter Config' to make your settings for the AC3-Filter
4. Create a new channel for Pro7 with audio-pid 257 and select AC3 (only Pro7 gives us AC3 )
