Guest Lars_MQ Posted April 15, 2005 Posted April 15, 2005 I've uploaded the OSD-Menu-Editor for DVBViewer 3.1 in the tools section of the Membersarea. With the editor you can customize and extend the OSD menu. The handling is selfexplaining. To get it in english language simply copy the english.lng for the language\Menuedit into the folder where the MenuEdit.exe resides and rename it to MenuEdit.lng. With the Editor you can - create own menus. (Add Homewindow) - call external programs (Add Program) - call other osd-pages (Add Hyperlink) - and call some of the internal functions of the DVBViewer (Add Script) The internal OSD-pages of the DVBViewer can only be limited changed for security reasons. Important: The DVBViewer has to be closed, if you edit the Windowdef.xml with the editor. In case something went wrong you can reset the osd menu by deleting the Windowdef.xml and start the DVBViewer. It will automatically create the default file. Of course all changes are lost in this case. Have Fun lars Quote
Guest Lars_MQ Posted April 16, 2005 Posted April 16, 2005 For people with knowledge in vb-script maybe this is of interest. You can put vbscript as example into a Programbutton (Add program): Program : "c:\windows\system32\wscript.exe" Arguments: "C:\programme\dvbviewer3\pip_open.vbs //B" of course you have to adjust this to your system and script. The " are necessary and the option //B means this script will be executed silent (no scripting window visible). lars Quote
