Problem after install of DirectX 9
Lele81
I have a problem with DVBViewer 1.98 R10. I have installed the newest version of DirectX 9 and then i see only a black screen. In the options are selected the Marphi's Render and the Overlay mixer. The signal bar is green. There's no audio and video.
Anyone have this problem and can help me?
I have also DirX9 and 1.98 R10 and it works fantastic.
Can you look with TV4PC? Or maybe it helps if you rebuild graph. Or have you probs with disecq?
The only problem was to rebuild graph. Now it's work perfectly.
Thanks a lot!
Another question:
I have a stab rotor, it's possible tu move the rotor with ss2?
i dont know anything about stab rotors (want also hav e one :rolleyes: ) But if you can move this with a diseq-signal than you can. But i dont know an other way.
Guest DAvenger
Well, the problem is that VMR9 does not support overlays at all. VMR7 does support them but in this case it does not need an overlay mixer present in the graph. I'd suggest that Christian rewrites a few lines of code and finally implement the XVR :rolleyes:
