Version 3.5
cockers
Hi there,
I spotted this WIP on the Status Ovreview page, and I have a couple of questions,
1. Which other brands are you planning to support?
2. Do you think it will be feasable to support two cards in one PC.
I only ask because I have a PC with a PCI Airstar and an old model PCI Hauppauge Nova-T.
Thanks,
Andy.
Guest Lars_MQ
There are working alphatests with bda-Drivers, so every Card with a bda driver would be supported.
The bda drivermodell supports multicard so there will be most likely support for it in the DVBViewer.
2. will take a lot of work and some changes so don't expect this in the too near future...
If, how and when this will be integrated is christians decision.
