Plugin SS2diseq problem
srg_1970
I have a problem with configuration the plugin MIBI SS2diseq 1.8. This plugin it's ok with progdvb configuration, but with DVBViewer 3 i have a problem with configuration and display this error :
Satellite : (0.0°E) 0000
Error...
when i change channel and satellite position.
Which is the configuration plugin whit DVBViewer?
The file .ini transponder change respect a progdvb?
Help ME!
My motor is SM3D12.
Thanks.
Guest Oliver
The SS2 doesn't feature DiSEqC >1.1, therefore the DVBViewer won't support it in any way, since it will damage your card. In case you're using a Twinhan compatible card: The developing team is working on it.
Bye
