wrong ratio on a few channel (ver 3.1)
k1509
On DW-TV and CNN the ratio for the picture is wrong. (most are fine) Should I try other filter or is it some setting? The manual says "Select the source filter at setting/option/enhanced". That setting seem to have been moved? Can not find where to change filter.
rgds
Thanks quick reply.
Found it under Help / 10. Small filter Guide / Which Filfers are used / about 15 line down
rgds
