sylphilds Posted November 3, 2024 Posted November 3, 2024 hi i want to know if with api it is possible to add in timer all tv programs for one channel for one day with command lines for example i must add one by one with epg page thanks for reply Quote
Griga Posted November 3, 2024 Posted November 3, 2024 3 hours ago, sylphilds said: i want to know if with api it is possible to add in timer all tv programs for one channel for one day Yes. But not with the API. Rather use the Web Interface -> Search EPG page. Have a look at the following screenshot: What you have to do: Enter an asterisk * in the "Search for" inoput line. It matches every text. Enter today+1 and today+1 in the "Date ... to ..." input lines to specify that you only want programs for tomorrow. Select the channel in the "Channels" list. You may also select more than one channel in the usual Windows way (e.g. Ctrl + click). Make sure that all checkboxes in the "Create auto-timers deactivated" section are unchecked. Enter a search preset name that is suitable. Click "Create Timers". This saves the search preset, so you can later select it in the "Search Preset" list, and creates timers for all programs of the selected channel(s) running tomorrow. Of course you can additionally modify the properties of the created timers on the right side of the search preset. There are also ways to let the timer creation happen automatically every day, instead of triggering it manually. More information about it on demand... Quote
