win 11 technisat skystar 2 eXpress HD
Stivano
hello guys i have technisat skystar 2 eXpress HD the DVBViewer not working with me version 7.3.0.0
iresearche from channel but i don't found anything and the signal worked perfect
and every time to try open the DVBViewer showed me that error
DVBViewer Pro Error Cannot load Source Filter, error: 0x80004002 No such interfa ce supported
my problem is showed in the pictures
any solution please need help
my regards
This error is known to occur in illegal DVBViewer copies, or if your user data is corrupted.
If you have an illegal copy, there is a simple solution: Buy DVBViewer and install a legal version.
If you own a legal DVBViewer licence, I'd recommend to uninstall everything (including the configuration and the user data) and re-install DVBViewer from scratch.
:thumbsup:
If you've been able to watch this tab so far, the only reason is the Windows Upgrade Cumulative Update.
You don't need to delete anything in DVBViewer, you just need to run the DVBViewer exe file you have installed again and the image is fine and the frequencies can be scanned. The settings in DVBViewer remain the same, including the list of channels. This tutorial also applies to other programs that do not work well.
