PVA splitter
Guest DAvenger
Guest DAvenger
As the topic says, this is not really a request but rather a sort of announcement. DVBViewer will come by default with its own PVA splitter filter and (hopefully) PVA/MPEG2 multiplexer filter. Also, it should be possible to record the stream without decoding it .... running just in background :rolleyes:
I bet lot of people will appreciate this as this means Elecard filters will not be needed anymore ;)
Wish us good luck :ph34r:
  • 2 months later...
  • 2 months later...
Guest DAvenger
Okey :D
Some pre-release beta should pop up later today ... without seeking support (but this should be implemented later - if everything goes well) :angry:
Take care,
DAvenger
