DVBViewer vrs Setup4PC channels
tr4veler
I recently picked up an Air2PC atsc pci card and am having a bit of trouble setting up the channels. DVBViewers scan picks up several channels but manyl do not have the proper description. Setup4PC scan list looks much better and is more complete. Is there a way to import the list from setup4pc into DVBViewer?
I am in California, USA will purchasing the full version get the EPG to work? Or does the american OTA broadcasts not include the data nessasary?
Feature Request-complaint : I get the B2C2 MPEG error message or generic tuner message for ofair messages. Is there a way to get an error message that reflects the difference between bad signal and no signal?
Guest Oliver
I don't think so. You're the first to ask for this. The TE is quite limited, though.
Well, the Pro version has a far more advanced scanner and as a registered customer you will also get TransEdit with even more enhancements.
http://www.DVBViewer.com/griga/Plugins.html#TransEdit
http://www.DVBViewer.com/oliver/Kanalliste.html
Bye, Oliver
i have also problem with channels.
i don't know how to ADD / EDIT the FAVORITES.
i don't know how to SORT the channels in the main Channel List
is there a plugin that i can import my progdvb channel to DVBViewer?
-thank you.
Edited by aktizol
Have a look at the last link, 2 posts higher. There is also a Channellist Editor inside the members area.
Guest Oliver
Editing favourites is not very comfortable with the TE. Do it this way: Tune the channel and press the yellow star button.
Sorry, I don't know how to do it with the TE. The Pro-version offers drag'n'drop, though, for favourites, too.
Im not sure but I think the TE can only import .ini/.txt-lists, maybe .sdx, too. BTW: With the Pro-version you shouldn't use 3rd party lists since they lack vital information (PCR, PMT...).
Maybe you should consider upgrading to CM&V's DVBViewer Pro:
http://www.DVBViewer.com/oliver/Einfuehrun...ml#einfuehrung2
Bye
