tisurame Posted May 14, 2005 Posted May 14, 2005 I can't just disable it !!! Every time I disable timeshift, it enable itself automatically. I already disabled "Automatic Timeshift" option, but it didn't worked. Anyone knows another way to disable it ? Maybe deleting some file...I don't know. Thanks. Quote
Guest Lars_MQ Posted May 14, 2005 Posted May 14, 2005 Be sure, your userdata you received on buying the pro version is correct. Quote
Klausing Posted May 18, 2005 Posted May 18, 2005 and please read pinned post in bug reports part of this board Quote
