ardee Posted May 16, 2005 Posted May 16, 2005 I've just got my Skystar 2 card working, and am now starting to find out what it can do. I have no use for Internet via broadband, SETUP/SERVER4PC, or the symbol in the task tray associated with it. Can I safely get rid of all this and just leave DVBViewer working. If so, how? Quote
Guest Oliver Posted May 16, 2005 Posted May 16, 2005 Can I safely get rid of all this and just leave DVBViewer working. You cannot. Bye Quote
Hartwig Posted May 16, 2005 Posted May 16, 2005 you must install the technisat software. But after that, you can remove Setup/Server4PC from autostart and disable all network protokols and services from your skystar. Quote
ardee Posted May 17, 2005 Author Posted May 17, 2005 Thanks for the replies. I find that if I remove server4PC from the startup menu, DVBViewer does not work. Is there a way of only running what is necessary for DVBViewer, and nothing else? Quote
Guest Oliver Posted May 17, 2005 Posted May 17, 2005 Usually the Technisat software only needs to be installed, not running. At least you don't need Setup4PC to run in the background. Bye Quote
ardee Posted May 18, 2005 Author Posted May 18, 2005 I've tried again, and I can run the full version without Server4PC in the startup folder but not the free version, so the problem is solved, thanks. Quote
