moeen Posted May 17, 2005 Posted May 17, 2005 hiiii all i got aproblem_ i need to recored to mpg vcd with DVBViewer but i dont know how? this is first and i try to use fiter maneger but i dont kone how i can to add it plz ineed help thanks for all Quote
Guest Oliver Posted May 17, 2005 Posted May 17, 2005 The DVBViewer saves the original data stream from the satellite directly to disk. The format is MPEG2. Bye Quote
Technofriend Posted May 18, 2005 Posted May 18, 2005 Try using Nero for instance. There is a trial available on www.nero.com Quote
moeen Posted May 18, 2005 Author Posted May 18, 2005 hi all thanks for crosing >>Oliver my dear i know its mpeg2 and i know ican stream it to vcd but it long way i need dirctliy im asking for if i can or how ? Technofriend<<thanks for u too i know nero but thir is programs more faster then nero like vedio studio and more pllz any one know tell me and this is my email mueenus101@hotmail.com Quote
Guest Oliver Posted May 18, 2005 Posted May 18, 2005 Sorry, I don't understand your request. Bye Quote
Rover Posted June 12, 2005 Posted June 12, 2005 hiiii all i got aproblem_ i need to recored to mpg vcd with DVBViewer but i dont know how? this is first and i try to use fiter maneger but i dont kone how i can to add it plz ineed help thanks for all <{POST_SNAPBACK}> Try going to this URL they have a great problem, I think it's what you are looking at doing with your files. http://www.dvdsanta.com/index.html?gc-03 Rover Quote
