SatWaveDude Posted February 16, 2025 Posted February 16, 2025 Hi, Can someone explain how to do a cable scan for the Belgian cable provider Telenet ? Frequency: 290000kHz Modulation: 256-QAM Symbolrate: 6789 Network-ID: 32 (Flanders and Flemish-Brussels) If I want to do a cable scan it does not provde to entering a Network-ID. Nor does it find anything if I scan the 290MHz 256QAN Symbr.6789 Do you think it still posible to scan with DVBViewer please let me now. The hardware I use is a USB device TechniSat CableStar Combo HD CI. Software DVBViewer DEMO 7.3.1.0 Quote
MaDu Posted February 16, 2025 Posted February 16, 2025 Maybe you have to use Symbolrate: 6875 https://wiki.openpli.org/Cable:Telenet Quote
SatWaveDude Posted February 16, 2025 Author Posted February 16, 2025 (edited) 2 hours ago, MaDu said: Maybe you have to use Symbolrate: 6875 https://wiki.openpli.org/Cable:Telenet of course I meant 6875 it was a typo. I would correct this but I can not edit my post. Thanks anyway ! Edited February 16, 2025 by SatWaveDude Quote
MaDu Posted February 16, 2025 Posted February 16, 2025 (edited) vor 5 Stunden schrieb SatWaveDude: Can someone explain how to do a cable scan for the Belgian cable provider Telenet ? Menue=>TV/Radio=>Reception Settings Available Reception Types=>DVB-C Transponder Lists=>Cable All=>Store=>Scan Edited February 16, 2025 by MaDu Quote
SatWaveDude Posted February 16, 2025 Author Posted February 16, 2025 6 minutes ago, MaDu said: Menue=>TV/Radio=>Reception Settings Available Reception Types=>DVB-C Transponder Lists=>Cable All=>Store=>Scan Already tried that, no results. Thanks. Quote
SatWaveDude Posted February 16, 2025 Author Posted February 16, 2025 I'm starting to suspect the TechniSat drivers. Now I'm going to test the AzureWave drivers, according to someone in the forum they should work. Unfortunately the Terratec H7 BDA drivers don't work for the CableStar Combo HD CI although the CableStar is a clone of Terratec I believe. Quote
MaDu Posted February 16, 2025 Posted February 16, 2025 Did you install the latest Technisat Driver Software ? https://www.technisat.com/assets/medias/common/61/$v2/SOFT_SkyStar-USB-2-HD-CI_CableStar-Combo.zip Quote
SatWaveDude Posted February 17, 2025 Author Posted February 17, 2025 (edited) 21 hours ago, MaDu said: Did you install the latest Technisat Driver Software ? https://www.technisat.com/assets/medias/common/61/$v2/SOFT_SkyStar-USB-2-HD-CI_CableStar-Combo.zip Yes, I have already tried that without success. Also installed another driver from AzureWave 7070 without luck. http://xxxxxxxxxxxx/download/files/AzureWave_30.08.2010.rar These drivers where reported as a workaround for the CableStar Combo HD CI device. It's strange as all seems to be okay no errors but it seems not to be scanning for some reason. Tested on two different laptops with Windows 7 x64 and no USB 3.0 since these drivers gives issues with USB 3.0 ports so it works best on USB 2.0 ports. Don't know what else I can try to get it to work. Edited February 17, 2025 by SatWaveDude Quote
